10-20-2006 10:19 AM
10-23-2006 04:36 AM
Well i dont really know how you ar connecting that amplifier and neither more about that.
The 5V - GND output pins from the card are directly out from the PC and there is no protection for that, so be carefull about connecting any active device to that terminals.
If you are experienciencing 50 Hz noise and you already have a shielded wire the easiest solution would be to implement any kind of filter to a lower frequency.
I dont know how is your input signal, but you can try with a hardware filter or with a programatical one (for example a low pass to 4Hz) done with labview to improve the quality of your signal.
Jaime Cabrera
NI applications engineering Italy/Spain
10-23-2006 05:44 AM - edited 10-23-2006 05:44 AM
Message Edited by gavril on 10-23-2006 05:48 AM
10-24-2006 02:22 AM
The CB-68-LPR is only a screw terminal (CB: connector block) were you can connect properly the signals, it is only a way to access to the card, so it has the same signals as the card.
If you are supplying the 5V-AIGND voltage from the Card, you can connect the shield of the cable to 0 Volts. If you are not (that means your amplifier-sensor have a different ground) then you should don't do that, because the GND of the card and the GND of the other part (sensor-amplifier) could be different and then you can experience the ground loop. Anyway it is extrange you got better results connecting the shield, because that way you are just making an RSE (reference single ended) measurement, and by the other way you make a differential one which is teorically inmune and rejects common mode voltage.
But anyway, if the 5V-AIGND are the same in the card that on the sensor-amplifier you can connect the shield to the AIGND of the card (or de 68-LPR) without problems.
Hope that helps,
Jaime Cabrera
NI Applications Engineering Spain/Italy
10-24-2006 02:38 AM
