10-23-2006 08:39 PM
10-24-2006 02:28 PM
11-15-2006 09:50 PM
11-16-2006 04:27 AM
11-17-2006 09:29 AM
Hi Bong,
It seems that your data is contained in one string you can separate the string out by using the String Subset function found in the string pallett. This will allow you to split the data apart so that you can then change it from HEX to a Number. This can be done by using hexadecimal String to Number which is in the String pallet also. Please look at this and let me know if you have any questions. You should also use the context help to explain these VIs further.
