compactRio-9025 connected but no identified network!
Hello
I use a cRio 9025, It was warking good, but actually I have a problem, it appears in MAX connected, but I have a problem that ithere is no identified network using the ethernet cable..
(3,402 Views)
What are the network settings you are using for the cRIO?
GCentral
(3,389 Views)
I'm using a Static IP, I did the same thing for my Ethernet connection..
(3,381 Views)
And what IP address did you use for the cRIO?
GCentral
(3,378 Views)
