How to Plot PWM signal(freq, DC and amplitude) on Waveform Graph/Chart
Hi All,
I am reading the PWM signal (generated from the source)using NI-Counter/Timer card into my code.
 I am getting the PWM signal frequency and DC values as the single nubmers by using DAQMx functions.
To verify I have to connect the oscilloscope and check if I am getting the correct signal which was generated at the source.
Instead of that , I want to plot the PWM signal itself on the LV front panel so that by just looking at the LV FP I can verify.
I tried using waveform graph , However I am not sure how to show the varying DC and Freq on waveform graph.
Any help is appreciated!
Message 1 of 1
(2,906 Views)
