Can i change module configuration i.e current to voltage using universal cRIO 9219 module
hi
Can i change module configuration i.e current to voltage using universal cRIO 9219 module.
if not then why?
regards
mazhar
Message 1 of 16
(6,111 Views)
Universal cRIO 9219 module can be configured to acquire different variables like voltage current and resistances. This requires one to configure the module by editing c Series module properties in project file. Is it possible to do the configuration at runtime? i.e can one during acquisition modify channel type from say voltage to current ?
Message 2 of 16
(6,110 Views)
Unfortunatly you cannot change the input mode for a channel on a 9219 at runtime. The modes are set in the module properties which can only be changed in the LabVIEW project. You can configure each cahnnel seperately so you can use different channels to meaure each type of signal. Check out the shipping example called NI 9219 Getting Started.lvproj in the example finder for a good example of how to do this.
Message 3 of 16
(6,084 Views)
If you're using the module in scan mode, I believe you can change the properties at runtime using a property node with a reference to the module. This code could be called in the Real-Time VI.
This won't work if you're programming the module directly from the FPGA as Hueter stated.
Message 4 of 16
(6,074 Views)
thanx Hueter for your time and interest i have checked that example.
Message 5 of 16
(6,061 Views)
Thanx GererdoG
but i have LabVIEW 8.6.1 and cant check the following code or is it possible in 8.6.1?
Message 6 of 16
(6,060 Views)
The programatic configuration API was introduced in LV2009, so you will not be able to access it from 8.6.1.
Additionally, it is not possible to change the mode of the 9219 at runtime.  Only the range for the deployed mode can be changed.  The screenshot posted implies that mode changes are possible, but in fact you will get an error from the property node if you attempt to change the mode.  Changing from current to voltage is a mode change, and is not permitted.
Let me know if you have any more questions.
Sebastian
Message 7 of 16
(6,046 Views)
Tank you speleato
right now i have no more question if i have any more question i will ask
thanx for ur intrest
mazhar
Message 8 of 16
(6,039 Views)
Thanks for clearing that up speleato and sorry about my misleading post.
Gerardo
Message 9 of 16
(6,032 Views)
Hi Speleato,
Jus seen ur post regarding the changing the mode in Crio 9219 module.
I want to change the mode programmaticaly, im ok with rebooting the system after the mode change. Is it possible?
Nanda
Message 10 of 16
(5,866 Views)
