Build Error with RT/FPGA Target
I am trying to build my RT project and deploy it to my cRIO 9014 chassis and I get the following error:
'An error occurred while saving the following file:
C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\rvi\ClientSDK\Core\ModuleGeneration\CommunicationInterfaceUtility\niFpgaDmaChannelImplementation.ctl
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_RTEXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Method Name: Save:Target Instrument
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 6 occurred at AB_Source_VI.lvclass:Close_Reference.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_RTEXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_RTEXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: Generic file I/O error.
NI-488: I/O operation aborted.'
The project uses a lot of FPGA capabilities of the 9014 and the four RIO modules in it. Please help!
(3,400 Views)
This is most likely due to the file path being too long.  A copy of this particular control is being saved within your rtexe file and the resulting path is longer than what the OS can handle.  On Windows, the maximum file path length is 255 characters.  Try moving the location of your build up in your directory hierarchy.  Maybe build the application directly to C:\ or one directory below like C:\builds.  This should eliminate the error you are seeing.
Donovan
(3,390 Views)
