05-15-2006 05:54 AM
05-18-2006 08:01 AM
Unfortunately this is not possibel, because the IVI drivers are not capable of being used accross the network. You are right that VISA Devices can be accessed via the Visa Server, but what you would have to do is use VISA calls to access the registers of the hardware, so programming the devices becomes very difficult.
Unfortunately you can not use the NI-HSDIO driver via a remote connection.
I would recommend to write an application for the remote system, that accesses the device, and has a TCP/IP interrface, so that you can ccommunicate with this application accross the network
05-30-2006 04:30 PM
Another option is to use Windows XP Professional on the remote system; then you can use Remote Desktop Client from another Windows computer to access the remote machine for adjustments or monitoring. You can also use the LabVIEW Remote Front Panel feature to view and operate the VI remotely. These options aren't the same as programming remotely with VISA, but perhaps one would be acceptable for your application...
RossC
