PXI
PXI 8186 RT - MAX FILE(.INI) CORRUPTED
Dear all,
Iam using a PXI 8186 RT controller running a tcp/ip 24*7.We have 18 fieldpoint controllers (Fp 1601) ,1 PXI 6527, 1 scxi chassis 1002 with 5 1531 cards connected to the pxi system.Recently i faced an issue in which the MAX file (*.ini) got corrupted in the controller.All the hardwares connected to the PXI were removed from the MAX automatically.We reconfigured all the hardwares & the system was running fine.Again the next week, we had the same issue & the controller failed to boot this time.Please let us know the actual reason for this problem.I had attached the actual error message with this mail for your reference.
(3,372 Views)
Hey Priya Chandar,
      The MAX database file becoming corrupt can be caused by a couple of different actions.  Please see these two links for additional information.
http://digital.ni.com/public.nsf/websearch/1E06DC0A338A52E886256FF2006C10E1?OpenDocument
http://digital.ni.com/public.nsf/websearch/B9107A7F281F9B408625720B0078E5A8?OpenDocument
Also, if you can send me the corrupt configuration file (as outlined in the second link), I'll report this problem to R&D for further investigation.  Thanks!!
Brian B
Account Manager
(3,364 Views)
