PXI
AIT 1553 RT support
we tried developing a project in labwindows realtime.Ni daq is working fine in this project.we tried AIT1553 ,though build succeeds at run time it is showing the following errorerror.png
 we have checked the software installed in host and target and r both same 2.54.2
We are using Labwindows 15 and LabviewRT Run time engine 16
Can anybody help to resolve this problem.
Regards
Preetha
(2,024 Views)
Hi Preetha,
It sounds like there may be a VISA driver mismatch. The AIT boards can be used with two separate VISA drivers, but one is required for RT systems. Can you post pictures of how your AIT card looks in Device Manager?
Also, there's another forum that has a PDF attached to one of the responses that I think would help. It's from AIT on how to switch between the two VISA drivers. I'm not an expert in RT or CVI so I'd take a look at that PDF and follow the steps to see if that helps.
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/AIT-MIL-STD-1553-PXI-not-communicating-with-...
(2,005 Views)
