11-16-2016 08:13 PM
Hello.
I'm using the "Logging - Logging Control.vi" in VeriStand 2014.
I want to set the "Start Logging button" programatically.
Then I use the "Start Trigger" and "Stop Trigger" to start the logging and stop logging with some VeriStand CHs.
First it needs to set the "Start Logging button" of the front panel to get the CH trigger ready on Workspace.
It needs to press the button manually once then it turns to the trigger waiting mode.
Does anyone know how I can set the button programatically with VeriStand-CH?
I don't want to use the Custom device "Embedded Data Logger" because the "Logging - Logging Control.vi" is very useful and simple, so it is helpful to tell customer the way to use.
Thank you,
Noriyuki
11-17-2016 09:35 PM
What exactly do you mean by programmatically? Do you want it to start as soon as the Workspace opens?
11-24-2016 08:12 PM
Hello Jarrod,
No, I don't. I would like to just press the "Start Logging button" to get ready to be triggered. The "Start Logging button" is red circled placed in the center.
It seems the "Start Logging button" has to be manually set before the trigger CH action runs so I want to run this button on Stimulus Profile Editor on desired timing.
Noriyuki
11-25-2016 12:15 AM
Hi Nori, unfortunately i don't have NI VeriStand now but, I think you can achieve the feature by customizing the workspace control.
As you know, we can edit all of control by LabVIEW. Does this answer satisfy you?
11-25-2016 01:13 AM
Hello Pignite,
Thank you for stopping by at this toppic.
yes, you are right but we can't open the block diagram side as usual with this control.vi. Maybe that is visually locked without password. If I can get the diagram code, I can edit code and inspect it. I think maybe they don't expose the source code.
Thank you,
Noriyuki
11-25-2016 01:58 AM
11-28-2016 06:30 PM
Sorry for the delay...
You are right, the VI cannot be modified... I don't know why it is locked...
I also checked VI property but, all property are grayed out : (
Does anyone know why it is locked?
11-28-2016 06:54 PM
Pignite,
Thank you for the checking VI.
I often heard from cutomer that The Logging Control.vi is more useful and understandable intuitively than using logging vi in SPE or the custom device logging tool.
That is visually understandable for beginner to change the target CH so I want to push it forward for customer.
Does anyone agree with it?
Thank you
