08-14-2014 11:45 AM
Hi. Has anyone had luck reading obd PIDs (e.g., $C for engine speed) using the ECU MC add-on for Veristand with an a2l file? What has to be done for this to work? 9188 compact DAQ chassis, 9862 module, General Motors ECM (ECU), Veristand 2011 sp1. Thanks. -KB.
08-18-2014 11:46 AM
Hi KB,
The ECUMC add-on for VeriStand will only work with the CCP/XCP protocols, not OBD-II data. To read OBD data, you can create a NI VeriStand add-on (http://zone.ni.com/reference/en-XX/help/372846G-01/veristandmerge/cust_device_overview/) utilizing the automotive diagnositc command set (http://sine.ni.com/nips/cds/view/p/lang/en/nid/203554).
