VeriStand
Data logging in custom format
We want to perform data logging, after selection of desired parameters to be logged (with the help of some sort of GUI/dialog), in custom format, probably in CSV format.
What are options available, is there any custom device already available?
Any help is highly appreciable.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(5,540 Views)
Check out the data logging API. It has a setting for text logging. See this example:
"C:\Program Files (x86)\National Instruments\LabVIEW 2012\examples\NI Veristand\API\Execution API\Data Logging\Text Logging - Basic.vi"
If that format isn't acceptable, you could log as a TDMS file instead, and then load/save the file into a different format using data plugins. ni.com/dataplugins
Stephen B
(5,527 Views)
I am new to forums and also to VeriStand. Even I have very similar requirement wherein I need log the data of various parameters into TSV format with a customizable column headers and some other info.
Before the data logging should start, user or operator should also be able to select what all parameters he wants to log.
Now I am not able to figure it out how to start with.
Somebody please help.
Few other questions are:
1. Is it possible to have a button on the GUI of VeriStand (Front Panel), which will allow to Start/Pause the data logging (in custom format as specified above)?
2. Can datalogging be done without using Stimulus Profiles? I mean directly from the VeriStand GUI.
(5,457 Views)
