NI TestStand
teststand API
I am creating a CVI interface that runs a Teststand sequence. I want to set/get variables from the StationGlobals of Teststand. I use this code to get a string:
if (TSTD_GetStationGlobalsString(ERR_RETURN_PTR, "TS.LastUserName", &result) < 0)
          printf("fail\n");
else
          printf("%s\n",result);
and the function TSTD_GetStationGlobalsString is as below:
int TSTD_GetStationGlobalsString( ERR_RETURN_DECLARATION, char* lookupString, char** pString )
int error = NO_TB_ERROR;
ERRORINFO errorInfo;
char* pTempString;
ERR_RETURN_INIT_NO_ERROR;
errChk (TS_PropertyGetValString (gStationGlobalsHandle, &errorInfo, lookupString, 0, &pTempString));
*pString = malloc(strlen(pTempString)+1);
strcpy(*pString, pTempString);
Error:
if (pTempString != NULL)
CA_FreeMemory(pTempString);
if (error != 0)
strcpy(*pString, "");
return -1;
else
return NO_TB_ERROR ;
this is working, howerver when I want to access another variable diffrent from TS it doesn't. Can someone help me please.
Thank you.
(4,679 Views)
What are you using as your lookup string?  If I have a StationGlobal called Foo then I need to pass just "Foo" as my lookup string.
Also, make sure the the StationGlobal exists or it won't work.  You can either use the PropertyExist method or use the InsertIfMissing flag (0x1).
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,678 Views)
Thank you for your help, I use "toto" as a lookup string, it's a string variable that I have added to the sequence. I have also checked the StationGlobal handle while debugging and it is not NULL. but it looks like it only has the defalut variables.
Edit: I actually cheked the station global using PropertyExist method and it returns True.
Thank you
(4,656 Views)
Sorry
PropertyExist method returns False.
Thank you
(4,647 Views)
Accepted by topic author Olfa
Problem solved, I only had to restart Teststand to save the new Sation Global ^^'
Thanks Smiley Embarassed
(4,633 Views)
Glad you figured it out!
jigg
CTA, CLA
testeract.com
(4,623 Views)
