Hi Steve,
either approach is perfectly valid, and as you say, the activeX approach does remove some of the flexability of where you get the data from, however, what you've really described is two separate things, rather than two separate styles of approach.
ActiveX or direct passing are simply the means of getting data from and to your TestStand data space.
Step types are a convenient way of wrapping up particular layouts and functionalilty into a very easily re-usable TestStand development item. You would still need some sort of code module to put with a step type, so you're not necessarily limiting your developed code to the Teststand environment.
Making links through ActiveX allows you to make a solid definition on configuration type items, and allow for edit substeps. For example, the NumericLimitTest step type has step.limits.high and step.limits.low. Rather than pass those to the edit substep as a dll call (which is perfectly valid), passing the sequence context (which also allows you to run the termination monitor etc) allows for the fixed references to the fixed data layout of the step. Self containment like this works when the data sources are fixed as you get with a step type to use the edit substep, or the pre/post substeps.
Working on a dll call allows more re-use because then you concentrate on the data, rather than where it's come from, however, for large amounts of different sources, the dll prototype can become very complex and difficult to document. You end up having to pass lots of parameters and some of them you might not use.
The question you're ultimately trying to answer is "what does it do to my architecture?"
The holy grail of TestStand architectures is any step type can be used in any sequence in any sequence file with any process model under any operator interface. Now this isn't always practical, but the closer you get to it, the more flexibility your system as a whole contains, and the easier it becomes to add in or change the layout / functionality of the system
With this comes code re-use, but the extra development time it takes to make good re-usable maintainable code isn't re-couped until the 4th or 5th re-use.
If you want in this case your passing of the array to occur from many different places in your sequences, and you're building up lots of sequences to use them, then making a step type, and passing through the most convenient method you decide upon will make the implementation of the sequences easier to do.
If you only need it in a couple of ways, then you can do without the step type, and if it's not many different data sources, then pass by parameter to the dll through the function prototype directly, and use a regular DLL adapter to acheive it.
Mostly my 2-cents worth.
Sacha Emery
// it takes almost no time to rate an answer
