02-24-2014 11:49 AM
Is it possible to cancel uut info dialog while working with parallel model? I want to use msg box input to enter product barcode. I want to generate a parallel testing sequence that will only ask for barcode entry to continue testing next board.
02-25-2014 01:29 AM
Its possible using callbacks.What version of TestStand are you using?
02-25-2014 01:40 AM
TS 2013. I'll appreciate if you can help me
02-25-2014 03:00 AM
Check the attached sequence.
Hope this is what you were looking for.
