NI TestStand
TestStand DataBase Query
https://forums.ni.com/t5/NI-TestStand/database-query/m-p/2753326
I make this query for TestStand DataBase query,
works fine, but you can modify as wish.
(6,058 Views)
Thank you for the query!!
Greetings
(6,018 Views)
Sure!
I hope somebody make an upgrade and share with us!
(4,514 Views)
Select
  [UUT_RESULT].[START_DATE_TIME],
  [STEP_RESULT].[STEP_NAME],
  [PROP_RESULT].[NAME],
  [PROP_NUMERICLIMIT].[COMP_OPERATOR],
  [PROP_NUMERICLIMIT].[LOW_LIMIT],
  [PROP_RESULT].DATA,
  [PROP_NUMERICLIMIT].[HIGH_LIMIT],
  [PROP_NUMERICLIMIT].UNITS,
  [STEP_RESULT].STATUS As STATUS
From
  (([UUT_RESULT] Inner Join
  [STEP_RESULT] On [STEP_RESULT].[UUT_RESULT] = [UUT_RESULT].ID) Inner Join
  [PROP_RESULT] On [PROP_RESULT].[STEP_RESULT] = [STEP_RESULT].ID) Inner Join
  [PROP_NUMERICLIMIT] On [PROP_NUMERICLIMIT].[PROP_RESULT] = [PROP_RESULT].ID
where [UUT_RESULT].[UUT_SERIAL_NUMBER] = '05981234' order by  [Step_Result].[ORDER_NUMBER],[STEP_RESULT].[STEP_INDEX],[PROP_Result].[ORDER_NUMBER]
Bill Lewis
(4,332 Views)
