NI TestStand
Run Seq immediately (auto) after UI start
 I have to run the Seq  file Immediately  after  I start The   User Interface   without  the Entrypoint Buttons
(5,179 Views)
Are you using a custom UI?  If so then you have several options.
Option 1: Button.DoClick.  You can call this method any time in your code for the TestStand button that is connected to your entry point.  This dynamically clicks the button.
Option 2: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9lvSAC&l=en-US
Option 3: http://www.ni.com/example/29301/en/
Hopefully these help,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,175 Views)
There are commandline parameters you can use to load and run a sequence, so just specify the correct commandline parameters when launching your UI. You can create a Windows' shortcut which does this.
-Doug
(5,145 Views)
Thanks guys.
Doug and Jiggawax,
This brings me to another question that has been on my mind:  I need to Create Custom Entry Point buttons on my Simple OI user interface.
What I want to do is the following:
* Create specific entry point buttons that point to and execute a subsequence within my main sequence file.  All of my subsequences that are being called in my main sequence are a certain type of test.  Can I use the command lines for this or is there a more efficient way to do this?
Thanks!
(5,119 Views)
Thanks Doug & Jigg
(5,103 Views)
See the following:
https://www.ni.com/docs/en-US/bundle/teststand/page/configuring-sequence-editor-and-user-interfac.ht...
There are command line options to run a specific sequence in a specific file, so you should be able to do what you are asking.
If you don't want to launch a new process though, you want a button on the existing UI, it might be best to create a new process model execution entry point or your own custom code for running such a sequence.
Hope this helps,
-Doug
(4,978 Views)
