NI TestStand
Property Loader FileGlobals Issue
I have discovered an issue with the Property Loader and the loading of FileGlobal variables.  I'm not sure if this is a bug or improper implementation by me but I couldn't find an answer in the reference manual. If I create a property loader step and load the following text from a csv file specifying the start and end markers I get an error.
Com Ports Start Marker
<FileGlobals>, Variable Value
COM_Port, "COM3"
Status_Light_Lines, "sally"
Com Ports End Marker
The error is:
-18; User-defined error code.
Sequence File: ITC_Test.seq
Property loader step failed to import or export properties.
2 property value(s) were found.
0 property value(s) were imported from 3 row(s) of data
After much thrashing I discovered that adding an empty row specifying Locals (even though I don't want to load any values), gets rid of the error and the FileGlobals values load as expected.
<Locals>, Variable Value
COM_Port, "COM3"
Do I need to outline each property category even if there aren't any to be loaded? It certainly doesn't seem so as I have loaded limits in a separate section just using the <Step Name> category without Locals, FileGlobals, or StationGlobals.
Anyway, this work-around certainly works for now. I just wanted to put this out there. I'm using TestStand 4.2.1.
(3,897 Views)
In the Manual Appendix C C-6 Loading from Files, it details the structure of the file. It doesn't say that you can miss items and if you use the Import/Export tool you get the complete structure regardless if you actual selected anything to export.
That said, it should be a bit more tolorent. I haven't tried this but I bet if you wanted a StationGlobals you probabaly would have to specify both Locals and FileGlobals.
Extract from Manual C-6
Start Marker
<Step Name> Limits.Low Limits.High Limits.String
Voltage at Pin A 9.0 11.0
Voltage at Pin B 8.5 9.5
Self Test Output "SYS OK"
<Locals> Variable Value
Count 100
<FileGlobals> Variable Value
Count 99
<StationGlobals> Variable Value
Power_On False
End Marker
Ray Farmer
Ray Farmer
(3,890 Views)
I have always included all the sections in my files for use with the Property Loader since TestStand 3.5....
<StepName>
<Locals>
<FileGlobals>
<StationGlobals>
The following link indicates you must have the tags even IF you are NOT importing a property or value, but this was TestStand 2.0.1.
http://digital.ni.com/public.nsf/allkb/2A4CA675B86CF70986256C2B00558D9A
PH
(3,880 Views)
