09-06-2009 03:01 AM
I have got following error when I execute sequence file
that contains while true loop, and within the loop two sequences.
The test ran 4.5 hours and then I got following error
Details: an error occured callong 'LogOneResult' of 'zNI Teststand Database Logging' an error occured executing a statement.
Statement: SETUP_RESULT. Description: [DBNETLIB][ConnectionRead (recv().) General Network Error. Check your network documentation.
Number: -2147467259
NativeError: 11
SQLState: 08S01
reported By: Microsoft Ole DB Provider for SQL Server
Source: TSDBLog
WrrorCode: -2147467259; User-defined error code.
Possible System error: Unspecified error
Location: Step 'LOgResult' of sequence 'ProcessModelPostResultListEntry' in 'Sequentional model.seq'
09-08-2009 04:02 PM
brt,
Can you reproduce this error? The error seems to indicate that there was some problems with connecting to your database. The error states that the error occurred when calling "LogOneResult" when logging your database, and it says "General Network Error", which seems to imply that there was a problem in connecting to your database at the time the error occurred. If this error is reproducible, then it might be something more, but if not, it was probably just a network error while your sequence was running.
