04-24-2009 11:40 PM
In the attached sequence I would like to load limits using a property browser. Some of the tests are in a loop. I would like to be able to specify different limits for each iteration through the loop. Is there a way to specify this in the property loader?
Mike
04-25-2009 02:10 PM
well, you must be able to do it as I did. but I think you need to change some execution preperty and put load dynamycally then you can specify the name of the file from which you want to read your limit by building his name with the expression browser
hopte it can help you
