NI TestStand
How to detect skipped steps using a callback
Hi all,
At execution time I need to detect when a step is skipped (for sequence analysis purpose and progression % calculus). This detection should be trapped for any sequence running my personnalized processModel.
In my case a step can only be skipped because its precondition failed.
I noticed that neither ProcessModelPostStep or ProcessModelPreStep callbacks are NOT fired for skipped steps... So do you have any idea to detect these skipped steps ?
Thanks.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(4,115 Views)
This is an interesting question.  You can look at the status of any step by using:
Step.Result.Status
Knowing this we could in essense use a SequenceFilePreStep callback and check the status of the previous step.
Runstate.Caller.Sequence.GetStep(runstate.CallingStep.StepIndex - 1, RunState.CallingStep.StepGroup).ResultStatus
Something like that?  You may have to use some sort of logic to determine if the step wasn't the first one in the step group?
Just a thought
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,108 Views)
Hi Jiggawax,
Thank you for your answer.
I guess I'll have to check if the step associated to the callback trigger is the first  non-skipped step in my sequence and update my actions according to this result...Not really efficient !
Moreover, doing some actions when a skipped steps is 'executed' could be necessary. I would have been great to have something like a 'ProcessModelCallback SkippedStep' or even better an option to allow 'ProcessModelCallback Pre/PostStep' to be fired or not for skipped steps.
(4,091 Views)
