NI TestStand
How do I customise the HTML report as follows?
1. Remove �Begin Sequence: MainSequence� and File path.
2. Remove �End Sequence : MainSequence�
3. Entire result table align in left of the page.
4. Get separate sub-sequence results, each in a separate sheet in order to avoid split tables.
(3,502 Views)
Hi MR SSL,
You will have to modify the reportgen_html.seq file.
Copy the file from ..\National Instruments\TestStand 3.0\Components\NI\Models\TestStandModels and to
..\National Instruments\TestStand 3.0\Components\User\Models\TestStandModels.
Now you can start to modify the reportgen_html.seq in the User folder.
To modify for item 1 and 2.
In the sequence 'AddSequenceResultToReport', set to skip of remove the following steps.
'Add Sequence Name'
'Add Sequence File Path'
'Add Sequence End Marker'
Item 3 - not sure what you mean by this. Do you mean remove any indents for subsequence results.
In the 'AddSequenceResultToReport' you will need to put a precondition Parameters.Level == 0 on the steps
Add Starting BLOCKQUOTE
Add Ending BLOCKQUOTE
T
his will remove the indent.
For item 4, well that is a bit more involved and I dont think it will solve what you what because it will depend if you limit the amount of information to say a A4 sheet.
I believe you will have to generate separate html file for each sub- sequence and then use the hyper-link TAG eg Sub-Sequence 1 to link them in the main document. Also you may what another hyper-link to get you back to the main document.
Hope this helps.
I have attached a modified reportgen_html.seq (TS3.0) for items 1,2 and 3.
Regards
Ray Farmer
Regards
Ray Farmer
(3,503 Views)
Hi any solution for new Version TestStand? I'm Using TestStand2020, which seems quite different from TS3.0
(1,323 Views)
