NI TestStand
Error on changing the teststand version from 2014 to 2010 using version selector
Hi All,
I am obtaining the following error when I try to change the active version of teststand.
Also I get the same error whenever I launch Teststand 2014. Any inputs in resolving it are welcome. Thanks in advance.
Prasaanth
(3,981 Views)
Prasaanth,
does this error also occur after a reboot?
What OS are you using?
Did you try a repair installation of TS 2014 in case a reboot did not help?
Norbert
Norbert
Expert: Geometry
(3,978 Views)
HI Norbort,
Yes this error occurs even after a reboot and I had already tried repairing TS2014. I am using windows 8 Pro.
Prasaanth
(3,976 Views)
Is TS 2010 working on the system?
Norbert
Norbert
Expert: Geometry
(3,974 Views)
It was working fine.Then I have moved to TS2014. In current situation, to launch TS2010 I will require to change the teststand engine from 2014 to 2010. This is where I face the isue.
Prasaanth
(3,971 Views)
Hi Norbert,
Thanks for your time. I tried repairing Labwindows/CVI runtime engine and it worked fine
(3,969 Views)
