NI TestStand
Error Occurred at Step 'Log Results to Database' of sequence 'Log To Database' in 'Database.seq'
Sometime, An Error Occurred at Logging Results to Database!
thanks!
(3,064 Views)
From the error message it sounds like the connection to the server was lost. Is the network connection to the server on an unreliable network? Did the server machine go down?
-Doug
(3,033 Views)
No! The server machine is ok,Because we have other test system was work well.
(3,014 Views)
