03-24-2008 03:36 PM
Solved! Go to Solution.
03-25-2008 06:30 PM
Hi Paul,
Since you already have the generated report files, it might be easier to simply use the LabVIEW controls to display the text file. For example, continue to open the HTML report using the TestStand ReportViewer and rather than using TestStand, open the ASCII Report using LabVIEW controls.
LabVIEW includes many examples to open and view a TextFile's contents.
You may find one at: C:\Program Files\National Instruments\LabVIEW 8.2\examples\file\smplfile.llb\Read from Text File.vi
Hope this helps.
03-26-2008 10:31 AM
03-27-2008 10:01 AM - edited 03-27-2008 10:06 AM
Yes, it worked. The attachment is my screenshot of the code that is contained in my custom UIMessage handler for LabVIEW. The StringData from the UIMessage is the HTML Report Path.
Thank you,
Paul Holzrichter
