10-30-2020 03:28 AM
I wonder if there is a simpler debug option, where I see the Steps Pane and the Variables at the same time.
Not in different Tabs.
Would make the debugging much easier.
Solved! Go to Solution.
10-30-2020 10:26 AM - edited 10-30-2020 10:28 AM
You can drag the tab and move to a separate panel, so everything is visible at the same moment 🙂
See this: https://zone.ni.com/reference/en-XX/help/370052AA-01/tsref/infotopics/seqeditwin_panes/
Edit: I've found a video as well: https://www.youtube.com/watch?v=ZM5LSY-xYQo
