10-10-2014 02:40 AM
Can someone help me? I am in China desperately trying to setup my test lines. My engineer that was working on all of this quit and I am trying to pick up where he left off. Our TS deployment was done in TS version 4.5.1.134, but the sequences were last saved in version 5.1.0.226.
Would someone be able to save my sequences (attached) in version 4.5.1.134 or earlier?
10-10-2014 03:22 AM
Here it is. Hope this works...
Good luck!
10-10-2014 03:45 AM
Thanks so much!!! It worked. I owe you a beer or two....
10-10-2014 04:17 AM
You're welcome.
Do you know Maredsous? I'm not a big fan of Tsingtao... ^^
10-10-2014 11:26 AM
For future reference, you can do "save as previous" in the TestStand Sequence Editor. When you do "Save As", select the corresponding version of TestStand from the "Files of Type" combo box. Then when you save, it will convert the file for loading in that version of TestStand (to the extent to which it's possible).
Hope this helps,
-Doug
