NI TestStand
Additional result
Hello NI,
i am using additional result step in TS
When adding any sting value to my report .below messege is coming along with the desired expected string.
same messege is also appending  in the report of  exmple run of additonal results.seq given by TS.
Status: Done Returned Expected StringTD BGCOLOR=#FFFFFF valign="top">AdditionalResults[0]: ''
please help me in geting rid of this undue messege.
regards
kulwant singh
Message 1 of 8
(3,643 Views)
Kulwant
Couple of questions
1.Did you make any modifications to reporting in TS 4.1?
1b. What is the report format you are using - XML or HTML?
2.Can you please attach the report generated after running the additional results example
Anand Jain
Message 2 of 8
(3,641 Views)
Also, if you could post a small example showing the problem.
Regards
Ray Farmer
Regards
Ray Farmer
Message 3 of 8
(3,637 Views)
Hello Anand,
Ya i have done couple of modification in the reporting part and i m using html format for reports.
kulwant singh
Evaluate result
Status: Failed
Returned String: abc
Limits:
   Expected String: abcd
Comparison Type: Ignore Case
Module Time: 0.0007784
End
Status: Done
End
Status: Done
For Each
Status: Done
For Each
Status: Done
If
Status: Done
xyz
Status: Done
Module Time: 0.0007542
Do While
Status: Done
errorClear
Status: Done
Module Time: 0.0021715
Pass/Fail Test
Status: Passed
Additional Results
Explaination: This Step should be Passed because a wrong SLIC was sent to instrument and an Error was expected
Returned Result: -224,"Illegal parameter value"
errorClear
Status: Done
Module Time: 0.0026023
End
Status: Done
Clear Error Stack
Status: Done
Module Time: 0.001337
DisConnect Instrument
Status: Passed
Module Time: 0.0165739
End Sequence: MainSequence
Message 4 of 8
(3,635 Views)
Hello NI,
just sending a Gentle reminder because did not hear from ur side about the problem..
Regards
kulwant singh
Message 5 of 8
(3,591 Views)
Kulwant
The modifications you have made to TS's reporting generation seems to be the cause of the problem. It looks like the html tags specifically <td> and <tr> are not being closed property.
I suggest the following
1. Revert your changes
2. Make incremental changes and verify that your changes do not mess up the report.
3. While you make the change please refer to link below.
A good resource for html is http://www.w3schools.com/. Please review this website to verify changes that you make to html tags.
Regards
Anand Jain
Message Edited by Anand Jain on 09-11-2008 12:48 AM
Message 6 of 8
(3,560 Views)
hi
Actully we have built our regression  test system using NI TS over an year and have done many changes  .some of them are  not even big enough that i didn't have any track of.so it would not be possible to do that.
No issue i ll find some other solution.Actully that additional result facilty was not their in ts 4.0 but is in ts 4.1
thanks for ur help!
regards
kulwant singh
Message 7 of 8
(3,556 Views)
Hi everybody.
Let me write a little preface: I'm working with TS 4.0 and unfortunately I can't use additional result tab, and I haven't got on my station.
During a test I plot a pop-up in order to notify a failure message if test fails. The test routine run on DI/O so in order to notify the line where the fails occur, the message plotted is indexed. I'd like to add the failure message (expression) to ReportText field of the pass fail step.
I'm trying to do this by using callbacks, I also tried to use Execution.AddExtraresult method but unfortunately doesn't run.
Any suggests for make this easy?
Thanks.
Message 8 of 8
(3,059 Views)
