10-25-2018 03:02 PM
I need help osilator circuit doesnt work
10-26-2018 11:52 AM
Have you checked the error message in detailed help? It seems to explain the source of the error and it also gives you some possible solutions. I recommend you to take a look at this (see picture attached).
Pamela Gómez
Applications Engineering
www.ni.com/support
10-26-2018 02:54 PM
Thank you for your help but Mixed mode Simulation settings have already set the ideal pin models when I changed "Use real pin models" I get singnal but it is fluctuating very rapid (frequency and voltage.)
11-07-2018 03:50 PM
disconnect the output of your gate from the power supply.
