07-11-2011 02:05 PM
Hello: My system, using MultiSim 11.0, doesn't do some Monte Carlo analysis properly. It acts like the computer's memory may be becoming filled up. And once a message appeared on my screen saying "Out of Memory." And some "runs" are truncated. Also some runs seem to have no ordinate values with the outputs overlaying the x-axis.
A different but similar circuit completed 15 runs. The runs were for .25 seconds each. The circuit is fairly simple including a 555 timer, some transistors, and passive components. I can't show the circuit.
What could be the problem?
ronquan
07-12-2011 09:04 AM
Hi Ronquan,
Select Simulate>>Analysis>>Monte Carlo Analysis>>Analysis Options, there is a field "Maximum number of points", increase this and see if fixes the "out of memory" problem.
If changing the setting doesn't work, can send us the file?
