06-12-2015 06:37 AM
is there an upgrade procedure for 6036e ?
We must replace a PCI 6036e daq card in an old labVIEW 8.6 system
06-12-2015 07:23 AM
It looks like NI is suggesting to replace the PCI-6036E with a PCIe-6341. As far as your software is concerned, just make sure the DAQmx device alias is set correctly in MAX and it should be fine. Hardware wise, you may need to change connectors and watch for pin changes.
