05-15-2008 11:07 PM
05-16-2008 03:18 PM
You'll usually receive this error if the kernel modules are not loaded. You mentioned that you ran updateNIDriver, but did it succeed? Were there any errors or warnings? The output of of niSystemReport could be useful as well. As root try something like:
@leh wrote:
I compiled and linked the function successfully but I get:
" libnipalu.so failed to initialize
perhaps you need to run updateNIDrivers"
I did this but to no avail. Now what?
05-20-2008 01:08 PM
05-20-2008 01:11 PM
05-20-2008 02:42 PM
05-20-2008 03:15 PM
05-20-2008 04:13 PM
05-21-2008 10:29 AM
02-19-2014 02:24 AM - edited 02-19-2014 02:27 AM
Hi
I am also facing same problem.
My System Configuration is -
OS : Red hat Enterprise Linux Workstation 6.4
with NI-6014 card.
I have installed nidaqmxbase-3.6.0 and nidaqmx-8.0.2f0 driver.
I performed all steps explained in above discussion, still error comes
'libnipalu.so failed to initialize Perhaps you meed to run updateNIDrivers'.
and also I checked in services nipal and nipxirmu, it shows both services are dead.
Please tell me how can i solve the problem.
02-20-2014 01:44 PM
NileshD,
You're posting on a thread that is 6 years old.
I did a search on the error and see a lot of similar posts. What have you tried/not tried so far? Is your system 64-bit?
Example search result post on similar issues
https://decibel.ni.com/content/thread/8785
