02-24-2010 05:01 AM
Hi!
I work on a LabVIEW code which uses 5 cards NI (6503,6023,6023,6503,6704). I want to simulate these cards. So I created Ni daqmx simulated cards. when I launch the labview program, I obtain the error -10401 when I try to use DIOconfig.vi. For information, I use the traditionnal daq driver 7.4.2.
Is it possible to call virtual peripherals ?
Thanks.
Solved! Go to Solution.
02-24-2010 06:15 AM
03-03-2010 10:42 AM
Thanks for your reply! I have another question. I work with daq-mx. Is it possible to write digital ouptuts and then read them just using Labview?
I work with LabVIEW 8.2. First I create a channel and start a task. Then I run a loop in which I write and read continuously the same port. But I never see this changing...
