04-02-2008 01:37 PM
04-02-2008 02:46 PM
04-03-2008 03:16 PM
poli,
If you are worried about your voltage level then you can use our Signal Conditioning hardware to address this concern.
NI SCXI-1104 : This module is part of our SCXI series. It will require a chassis and connector block.
NI 9229 : This module is part of the CompactDAQ line, it will come with a USB connection sleeve.
If you go to ni.com/ask, you can contact NI Engineers to help configure a system for your application.
I hope this helps!
