Multifunction DAQ
NiDAQmx and 6220 board - Retriggering to start sampling analogue signals
I have a M series 6220 board with labview 7.
I want to measure analogue signals using a digital trigger - much like the examples given in the library shipped with ver.7. However I want to "retrigger" periodically so that I can sample the my analogue signal each time my external circuit sends a trigger pulse out. This retriggering facility continuing until I press a stop button.
At the moment all I can do is get one triggered set of samples and then the VI stops.
Any code advice or examples would be appreciated.
rgds
Charles (labview beginner)
(2,876 Views)
Hi sch,
This example will start and stop aquisition with a digital signal to a PFI line.
Hope this helps.
(2,873 Views)
Many Thanks DavidT
- unfortunately the code won't run on Labview ver 7.0.
Any suggestions
rgds
Charles.
(2,864 Views)
Ive saved it to LV7.0 and attached a gif image in case you have any problems with the VI.
(2,852 Views)
Many thanks you have me rolling again.
(2,842 Views)
