Multifunction DAQ
NIDAQmxBase Linux RHEL 6 x86_x64 USB...
Trying to get NIDAQmxBase 3.6 w/ USB support for installed on LINUX RHEL 6.3 x86_x64 WS
USB 6501 OEM,
USB 6009 OEM
running as root:
[root@NIX1 /]# mount
usbfs appears to be mounted..  etc/fstab modified to mount as shown
/dev/mapper/vg_nix1-lv_root on / type ext4 (rw)
proc on /proc type proc (rw)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw,gid=5,mode=620)
tmpfs on /dev/shm type tmpfs (rw,rootcontext="system_u:object_r:tmpfs_t:s0")
usbfs on /proc/bus/usb type usbfs (rw,devmode=0666)
/dev/sdb1 on /boot type ext4 (rw)
/dev/mapper/vg_nix1-lv_home on /home type ext4 (rw)
none on /proc/sys/fs/binfmt_misc type binfmt_misc (rw)
sunrpc on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw)
/dev/sr0 on /media/NIDAQmxBase360 type iso9660 (ro,nosuid,nodev,uhelper=udisks,uid=500,gid=500,iocharset=utf8,mode=0400,dmode=0500)
lsdaq runs and complains about firmware:
[root@NIX1 /]# /usr/local/natinst/nidaqmxbase/bin/lsdaq
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
Device Error: incompatible firmware.  Serial Number: 01646C23
Execute <NI-DAQmx Base directory>/bin/FWUpdate to update.
green light on USB 6501 is blinking steadily
running FWUpdate compains as follows:
[root@NIX1 /]# /usr/local/natinst/nidaqmxbase/bin/FWUpdate
Can't load library /usr/local/lib/liblvrt.so.12.0
libXinerama.so.1: cannot open shared object file: No such file or directory
To download the LabVIEW Runtime engine, go to http://www.ni.com/rteFinder?dest=lvrte&version=12.0&platform=Linux&lang=en
locating /usr/local/lib/liblvrt.sa.12.0 reports:
[root@NIX1 /]# locate liblvrt.so.12.0
/usr/local/lib/LabVIEW-2012/liblvrt.so.12.0.0
stat on file reports:
[root@NIX1 /]# stat /usr/local/lib/liblvrt.so.12.0
  File: `/usr/local/lib/liblvrt.so.12.0' -> `LabVIEW-2012/liblvrt.so.12.0.0'
  Size: 30            Blocks: 0          IO Block: 4096   symbolic link
Device: fd00h/64768d    Inode: 131699      Links: 1
Access: (0777/lrwxrwxrwx)  Uid: (    0/    root)   Gid: (    0/    root)
Access: 2012-10-22 14:27:59.858557301 -0400
Modify: 2012-10-22 14:27:59.813443661 -0400
Change: 2012-10-22 14:27:59.813443661 -0400
NIDAQmxBase 3.6 installs VISA and "C" interface via .\INSTALL, reports success, looks normal.
cannot successfully run lsdaq, FWUpdate, or anything on the National Instruments Applications Menu (NI-VISA submenu,  NI I/O Trace.)
My guess is the permissions are still hosed.
(5,092 Views)
libXinerama.so.1   is elf64 x86-64
and is trying to link to /usr/local/lib/liblvrt.so.12.0 which is elf32 i386
(I though only I did that...)
from installed NI-VISA/README
SYSTEM REQUIREMENTS
NI-VISA 5.2 for Linux software requires one of the following distributions:
    openSUSE 12.1
    openSUSE 11.4
    Red Hat Enterprise Linux Desktop + Workstation 6
    Red Hat Enterprise Linux Desktop + Workstation 5
    Scientific Linux 6.x
    Scientific Linux 5.x
Currently, only 32-bit applications are supported on the x86-64
architecture.
And in NIDAQmxBase readme:
OPERATING SYSTEM SUPPORT
NI-DAQmx Base 3.6.0 supports:
openSUSE 11.4 and 12.1,
Red Hat Enterprise Linux WS 5 (x86/x86_64) and 6 (x86/x86_64),
Scientific Linux 5.x and 6.x,
and Mac OS X v10.6.x (x86/x86_64) and v10.7.x (x86/x86_64)
Currently, only 32-bit applications are supported on the x86-64 architecture.
So I need to install 32 bit version of libXinerama before running these, because only 64 bit is installed by default.
(5,084 Views)
Accepted by topic author Frediano
Resolved, and was able to update firmware.
Well explained here...  http://digital.ni.com/public.nsf/allkb/93C92D41B25341B286257A4D007BACB8
and useful how-to here.  http://h10025.www1.hp.com/ewfrf/wc/document?cc=ca&dlc=en&docname=c01769573&lc=en
(5,081 Views)
