Multifunction DAQ
How to install parallel Traditional DAQ and DAQ mx in Windows 7
Resolved with Traditional NI-DAQ (Legacy) 7.5 for Windows 2000/XP/Vista/7 - BETA and DAQmx Version 9.2.2
Adding Traditional Support for an existing System with installed mx drivers.
You need both unpacked installation package folders.
Install Traditional Driver 7.5 Beta, maybe you need to do this by selecting Compatibility Mode as for a Vista Installation.
Go to your NIDAQmx Installer Directory --> Products NI-DAQ_INF_files --> infInstaller.msi.
Right click --> Uninstall.
Go to your Traditional 7.5 Beta Installer Directory --> Products NI-DAQ_INF_files --> infInstaller.msi
Double click --> Install and proceed with click Next, Next, Finish.
Check in Windows Device Manager if Driver Date is now 9/19/2007
and Driver Version 1.0.0.16384 or similar 1.0.xxx.
Restart your System.
Check in MAX if your Device is shown in MX-Tree and Traditional.
This worked for me for a NI DAQ PCI 6025 e card.
I used WES 7 Standard SP1 32bit / x86. I have confimation that it should work on any Windows 7 32bit as well.
Software and System Tester
Message 1 of 12
(9,384 Views)
Thank you very much!
Message 2 of 12
(9,134 Views)
Hi Thomasw76,
Do you have a solution for Windows 7 64-bit?
The Traditional 7.5 beta throwing the error "This version of Traditional DAQ is supported only in Windows XP/2000/Vista32".
Thank you.
Message 3 of 12
(8,495 Views)
As far as I know there is only support for 32bit in 7.5 Beta Traditional.
Maybe 32bit on WOW 64 is a solution but I dont know how to set up this.
This graphic shows the middle column what I mean. maybe this is a help to get to the point of working this issue.
Best regards
Message 4 of 12
(8,484 Views)
I got it running the same way even under Windows8 embedded 32bit, woohoo!
best regards
Thomas
Message 5 of 12
(8,479 Views)
How did you do the setup?
Message 6 of 12
(8,473 Views)
Worked as well with DAQmx 9.7.5.
Before I did "Go to your Traditional 7.5 Beta Installer Directory --> Products NI-DAQ_INF_files --> infInstaller.msi" I just deinstalled the Driver of the PCI-Card in Windows Device Manager manually - just to be sure.
Everything else as described above.
Message 7 of 12
(8,346 Views)
I need Know what is the drivers for intaller NI DAQ Legacy 7.5 for windows 7 somebody help me ?
best reagards
Message 8 of 12
(4,459 Views)
NI did a Release of Tradional Driver 7.5 as Installer for x86 / 32 bit. But it is not available anymore to download. With this Release it was not necessary anymore to do the „.inf“ trick. I have one copy of it in my company repository. I try to share it some how on a web drive.
It works for Windows 7 / Windows 8  and even with Windows 10 32 bit. I use it with Windows 10 IoT Enterprise 2019 32 Bit for our company measurement pc.
best regards
Thomas
Message 9 of 12
(4,445 Views)
I did find a 7.5 Beta, not sure what is in it-
http://download.ni.com/#support/daq/pc/ni-daq/traditional/
-AK2DM
Message 10 of 12
(4,418 Views)
