Multifunction DAQ
Errors while starting Measurement & Automation Explorer
Hello!
while starting Measurement & Automation Explorer I get the following error messages:
CmdExecutionThreadPool::DoWorkNonUI
and
Exception in CmdProviderWrapper::BindPrimary function of NIMax process.
The installed PCI-6111 card does not show up in the device list.
I thought the driver might not be installed correctly, but when I try to install it again. The installer won´t let me do it and tells me that nothing will be installed.
Is there a different way of updating the driver?
Does anybody know what this means?
Thanks!
Matthias
(3,409 Views)
Now I found out that the PCI card is not installed correct. In the device manager it just shows up as a PCI device.
But I can´t reinstall the driver. Where do I have to search for the right driver?
As I said the regular installation does not work.
Thanks!
Matthias
(3,402 Views)
Hi Matthias,
which version of the DAQmx driver do you have? You can download the driver here. Please be sure that you download a version that matches your device and OS
Kind regards
Carsten
(3,375 Views)
