Multifunction DAQ
DAQCard-AI-16E-4 Config Utility vs VB command set.
The National Instruments Config Utility allows me to select the mode of the
card for analog input. I can choose differential, single-ended referenced
or single-ended non-referenced. Can I set these parameters using VB
commands or does the user need to make sure the configuration is correct in
the Config Utility manually?
Message 1 of 1
(3,167 Views)
