Multifunction DAQ
DAQ matlab lowpass filter enabling
Hello everybody,
I'm trying to activate the internal lowpass filter of the NI6120 DAQ with Matlab. I tried the following skript but I didn't work.
Additionally I'd like to know if it is possible to use the DAQ-Toolbox of Matlab to use the counter for frequency measurement. If not is it difficult to implement it?
Thanks a lot
Markus
    %Filter Property
    DAQmx_AI_Lowpass_Enable = hex2dec('1802'); % Specifies whether to enable the lowpass filter of the channel.
    %Activate LOWPassFilter
    taskLP=uint32(1);
    [a,b,taskLP] = calllib('myni','DAQmxCreateTask','LP',taskLP)
    disp('LOWpass');
    %--- C-Code to enable Filter
    %int32 __CFUNC DAQmxSetAILowpassEnable(TaskHandle taskHandle, const char channel[], bool32 data);
    disp('set LowpassEnable');
    Data = DAQmx_AI_Lowpass_Enable;
    [a,b]=calllib('myni','DAQmxSetAILowpassEnable',taskLP,taskchans1,Data)
    %--- C-Code to get if Filter is enabled
    %int32 __CFUNC DAQmxGetAILowpassEnable(TaskHandle taskHandle, const char channel[], bool32 *data);
    disp('Get LowpassEnable');
    DataPtr = libpointer('uint32Ptr',Data);
    [a,b,cc]=calllib('myni','DAQmxGetAILowpassEnable',taskLP,taskchans1,DataPtr)
    [a] = calllib('myni','DAQmxStartTask',taskLP)%for LP added
    [a] = calllib('myni','DAQmxStopTask',taskLP);%for LP added
    [a] = calllib('myni','DAQmxClearTask',taskLP);%for LP added
(5,106 Views)
Hello Markus,
I think the problem is related to the fact, that no channel is created before calling the function DAQmxSetAILowpassEnable(...). You should call the function DAQmxCreateAIVoltageChan(...) before calling the function  DAQmxSetAILowpassEnable(...).
A C-Example with these function calls could look like this:
int main(void)
    TaskHandle  taskHandle=0;
    // DAQmx Configure Code
    DAQmxCreateTask("",&taskHandle);
    DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0","aichann",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL);
    DAQmxSetAILowpassEnable(taskHandle,"aichann",TRUE);
The only information I have concerning your question about the Matlab DAQ-Toolbox is a list of the supported NI-hardware which can be found under: http://www.mathworks.com/products/daq/supportedio14005.html.
I hope I could help you.
Blase
(5,076 Views)
Hi Blase,
thank you for your response.
The code I have written was only an excerpt of my programme, that's the reason I have forgotten to mention the create function.
 -----THis was missing-------
% Other constants must be searched in the NI installation directory
DAQmx_Val_Volts= 10348; % measure volts
%Filter Property
DAQmx_AI_Lowpass_Enable = 1; % Specifies whether to enable the lowpass filter of the channel.
disp('NI: Create Tasks')
taskh1=uint32(1);
[a,b,taskh1] = calllib('myni','DAQmxCreateTask','master',taskh1)
% a will be the error code
disp('NI: Create AI Channels')
taskchans1=['Dev1/ai0:' num2str(numofchans-1)];
[a,b,c,d] = calllib('myni','DAQmxCreateAIVoltageChan',uint32(taskh1),taskchans1,'',-1,-10,10,DAQmx_Val_Volts,'')
followed by the older code sequence
    taskLP=uint32(1);
    disp('LOWpass');
I'm not sure what's the reason so that it's not working properly. I have also changed the entry of the filter value
DAQmx_AI_Lowpass_Enable to 1 instead of true.
best regards
Markus
(5,061 Views)
Hi Markus,
I had the same problem and was able to get it to work by writing a shared library (ni6120.dll) and then calling the external functions in my matlab code.  I've attached the code I used.  You can look at the script lowpass.m to see how to call the library functions.  Setting dofilt=1 in the code will use the 100 kHz AA filter, and dofilt=0 will disable the filter.
-Dave
(5,042 Views)
Hi Dave,
Thanks a lot. And sorry for the late response, but I was ill the last view days.
Markus
(4,969 Views)
