ni.com checkout is currently experiencing issues.
Support teams are actively working on the resolution.
02-13-2011 05:29 PM
Hi
Is it possible to drive the USB 6212 using LabView 7.1 on a Xp-32 bit platform? I install the DAQmx 9.0.2 but there is not DAQ assistant in tools of Labview 7.1.
02-13-2011 06:09 PM
02-13-2011 10:28 PM
Hi Dennis
Thanks to your reply. Your observation is correct. I installed the driver, my DAQ is recognized by Windows. However, when I put DAQ assistance in the block diagram, the initialization doesn't work and I get an error message.
Cheers
02-13-2011 10:48 PM
Being recognized by windows is not relevant since your original 9.0.2 installation is valid for xp. I suspect that there were remnents left over that the uninstall of 9.0.2 did not remove. Try it again with msiblast.
02-13-2011 10:56 PM
Indeed, I remove all Ni Tools before I install DAQmx-8.9, But I try with MSIblast
Thanks again to your help!!!
02-14-2011 01:42 AM
Hi
I install again LabVIEW 7.1 and NI-DAQmx-8.9. And I get the same error message: "Some components required for editing are missing.". (even if the USB 6212 is not connected)
cheers
