Multifunction DAQ
6024E works with DAQmx but doesn't work with Traditional DAQ. Why?
I have a 6024E. The board was working with LV 6 and DAQ 6.9. Then I decided to upgrade to LV 7 and I installed the Traditional DAQ 7.0 and the DAQmx drivers.
Now when I go in MAX I see the 6024E listed both under traditional DAQ devices and under DAQmx. However, only under DAQmx I can run the test panel utility. Under Traditional DAQ the test panel button is disabled.
If I try to place in a new vi the simple "AO one point" I get a bad error and the system crashes (I need task manager to end the process).
I read some posts around and I've heard that I am supposed to reset the device every time I want to switch between traditional DAq and DAQmx, however, the "Reset Device" in MAX doesn't solve my problem.
The only thing I would like to achieve is being able to use the "AO one point" or the "AI config" vi that i already have implemented in my applications.
Hope someone can help.
DanMSU
(2,891 Views)
that's strange!
Just do one thing.
try uninstalling and reinstalling the DAQmx ans traditional DAQ drivers and see if it works
(2,881 Views)
I tried to uninstall and reinstall the drivers many times, with no success.
However I finally upgraded to the Traditional DAQ 7.4 and that solved my problem!
DanMSU
(2,864 Views)
helo
I also have a 6024E PCI card and want to use it with Labview 6i under Windows2000, I called the NI phone service and they told me to DL the traditional drivers but I couldn't download them, could somebody help me in finding them, I found a link on NI website but I couldn't download it and have an error message, many thx
(2,743 Views)
Sieg,
You can find the driver download page here (Product Line is Multifunction DAQ, Software is Traditional NI-DAQ (Legacy) ). KB 3PIA89N5 is also a great reference for the compatibility between driver versions and LabVIEW.
David L.
Systems Engineering
(2,727 Views)
