The way I've attempted to work around this is by first setting the minimum
setpoint to zero, calling Reset(), and then setting the minimum setpoint
back to what it should be. I'm not sure how the control responds to having
the minimum setpoint changed during cycling (and after calling Reset). I've
also noticed that after calling Reset() the setpoint used by the control
is automatically set to zero.
"Chris Matthews" wrote:
>>Hi Matt,>>We have verified this bug and are working on a fix for it. Please
reply>directly to me and let me know how critical this fix is to you so I
can advise>you on your options.>>Best Regards,>>Chris Matthews>Measurement
Studio PSE>>"Matt Flinders" wrote:>>>I have been
using Comp
onent Works Autotuning PID control for a temperature>control>mechanism.
After setting up the control with the appropriate parameters,>calling>the
control's Reset() method causes an exception to be generated>that reads>"Value
out of range". It appears to be associated with changing>the minimum>setpoint
value of the control. This behavior can be reproduced>by modifying>the AutotunePID
sample that comes with the control. Create a>new method call>which first
sets an arbitrary new minimum setpoint and then>calls reset as>demonstrated
below. >>m_cCWPID1.SetSetpointMin(5);>m_cCWPID1.Reset();
