06-28-2010 10:12 PM
Hi Guys,
I am trying to plot data from my table, and want to plot a date time value on the x axis and the temperature value which will look like 32.5c
on the y axis on a waveform chat. I am new to measurement studio, anyone have an example on how this is done?
I have a for loop which loops and gets the data from each row ( the time and temp) and i want to plot in each loop as i go,
so the graph will be building, and the user can see it building until i have read all the records.
Solved! Go to Solution.
06-29-2010 06:56 PM
Hi lil_racoon,
A waveform chart normally uses a 1D array with indexes and you can manually adjust the x-axis. If you are looking to plot data from a 2D array you will want to use the scatter graph and make a scatter plot. I would take a look at this tutorial on how to create custom scatter plots and waveform plots.
06-29-2010 07:14 PM
Thanks, will take a look, is it possible in scatter groph to plot against a datetime on the xaxis? or it has to be numeric values
06-29-2010 07:28 PM
Also in scatter graph u can plot with x y however it takes only a double value for x, and i have a date time value for my x, do i have to convert that to seconds? if so i want this to be represented as a date time value on ma x range rather than in seconds
06-30-2010 01:31 PM
Hi lil_racoon,
Thank you for the additional information. After looking at what you are trying to do, I beleive that the attached code will accomplish your goal. Try to adjust it to work for your application.
06-30-2010 04:55 PM
Thank you so Much Ryan! =D thats exactly what i want!
