06-22-2015 04:04 PM
Hi again,
this is the situation in the target computer when the setup is OK but the designer mode not in the dev. machine:
br,
Ilkka
06-22-2015 04:12 PM
Here is the Common.wxs..
br,
ilkka
06-22-2015 04:33 PM
This runs ok in the dev. machine..
Maybe this file must be updated in the Common.wxs:
<Merge Id="MStudioCommon" Language="0" SourceFile="$(var.MergeModulesDir)\MStudioCommon.2012_x64.msm" >
06-22-2015 04:54 PM
What versions of the MStudioCommon merge module do you see here: C:\Program Files (x86)\Common Files\Merge Modules on your development machine? If you have versions other than 2012, would you mind posting them here?
06-22-2015 10:58 PM
Hi Daniel,
Here are the MStudioCommon merge modules:
Directory of C:\Program Files (x86)\Common Files\Merge Modules
09/29/2014  06:25 PM           308,736 MStudioCommon.2010.msm
09/29/2014  06:25 PM           311,808 MStudioCommon.2010_x64.msm
09/29/2014  06:43 PM           307,200 MStudioCommon.2012.msm
09/29/2014  06:43 PM           307,200 MStudioCommon.2012_x64.msm
Maybe we need 2013 version..?
BR,
Ilkka
06-23-2015 07:54 AM
06-23-2015 09:06 AM
Hi Daniel,
Here are the files.
BR,
Ilkka
06-23-2015 02:43 PM
Thanks, Ilkka. After some further investigation, it looks like the 14.2 version of NationalInstrument.Common did not ship with a corresponding merge module that deploys it. I am in the process of tracking down whether one exists internally, and if I find it, I will post it immediately.
You have several options going forward to solve / work around this issue in the meantime:
I'll update you again as soon as I can.
06-23-2015 03:18 PM
Hi Daniel,
Oohh thanks; I did not know that the Measurement Studio 2015 is officially published. I will test it.. We see tomorrow the results. 😉
Have a nice day,
Ilkka
06-24-2015 07:31 AM - edited 06-24-2015 07:41 AM
Hi Daniel,
OK.. The Measurement studio is upgraded now to the ver. 2015. It is very good.. The designer mode works and also the old WiX setup project is OK. I do not know what had happened but now the setups in the target computers work with the newest assemblies:
Thanks for the great support.
BR,
Ilkka
PS: I tested the new measurement Studio Installer Builder. It seems to be nice product but I cannot add registry keys for handling the file extensions so that our software will be a default program for our data files. The registry values will not stay in the Installer Builder project.. I will make a new thread about this later.
