Change the Color Map of the Intensity Graph at Run-time
Recently I've found out that the ColorScale class of the Intensity Graph has the ColorMap property as a read-only one. I am wondering if it is any way to change the ColorMap of the Intensity Graph at Run-time.
Thank you in advance.
(6,448 Views)
Hi PLK,
I was able to change the ColorMap property of the IntensityPlot (a member of the Intensity Graph) using the following code (in C#, MStudio 2012, VStudio 2010):
intensityPlot1.ColorScale.ColorMap.Add(0, Color.FromArgb(redValue[0], greenValue[0], blueValue[0]));
intensityPlot1.ColorScale.ColorMap.Add(50, Color.FromArgb(redValue[1], greenValue[1], blueValue[1]));
intensityPlot1.ColorScale.ColorMap.Add(100, Color.FromArgb(redValue[2], greenValue[2], blueValue[2]));
If you try to change the intensityGraph1.ColorScale.ColorMap, the scale and plot won't line up. You have to change the color scale of the plot to see a change, and the color scale of the graph to change the legend.
Let me know if this gets you going in the right direction!
Alexandra
(6,439 Views)
Hi Alexandra,
Thanks for the right direction you have guided me to. In my opinion, it is more advantageous to use the AddRange member of the ColorMap object. It will add a whole color map at once. So, I've ended up with the following:
// Create the small Rainbow color map
double ScaleMin=intensityPlot1.ColorScale.Range.Minimum;
double ScaleMax=intensityPlot1.ColorScale.Range.Maximum;
double valLen=ScaleMax-ScaleMin;
double[] values={ScaleMin,ScaleMin+valLen/4,ScaleMin+valLen/2,ScaleMin+valLen/4*3,ScaleMax};
Color[] colors={Color.FromArgb(0,0,255),Color.FromArgb(0,255,255),Color.FromArgb(0,255,0),
                        Color.FromArgb(255,255,0),Color.FromArgb(255,0,0)};
IntensityColorMap cMap=new IntensityColorMap(values,colors);
Minimum and maximum values of the scale are required in more general case when the scale has the Auto-range property
// Change the color scale of the plot
intensityPlot1.ColorScale.LowColor=colors[0];
intensityPlot1.ColorScale.HighColor=colors[colors.Length-1];
intensityPlot1.ColorScale.ColorMap.Clear();
intensityPlot1.ColorScale.ColorMap.AddRange(cMap);
It is important to change the LowColor and HighColor of the ColorScale to the boundary colors of the new ColorMap, because it won't adjust them automatically
// Change the color map of the legend
intensityGraph1.ColorScales[0].LowColor=colors[0];
intensityGraph1.ColorScales[0].HighColor=colors[colors.Length-1];
intensityGraph1.ColorScales[0].ColorMap.Clear();
intensityGraph1.ColorScales[0].ColorMap.AddRange(cMap);
Following you tip I've done all changes on the ColorMap for the first element of the graph ColorScales array in order to adjust the graph legend as well. And finally
// Redraw the graph
intensityGraph1.Refresh();
This approach is working well. Thank you again for your help.
Sincerely,
Pavel
(6,434 Views)
