Machine Vision
writePNGfile - error 1074395995 file not found on saving big images
Hey there,
I'm trying to save an image which i aqcuired through the PCIe 1427 Framegrabber connected to a Basler L803k.
For this i created a file dialog with the filename pattern *.png, which then sends the selected path to an IMAQ Write File 2.vi set to PNG with a compression level of 750.
Doing all this works fine for 8160x2000 images, if i change the image proportions to 8160x6000 however, i'm recieving the beforementioned 1074395995 error.
Any idea how to solve this?
Thanks in advance
Mathias
Edit: I'm using LabView 9.0 with NI-IMAQ 4.5 on a P4 3GHz / 2GB RAM / Win XP
(3,844 Views)
The issue magically fixed itself somehow.
No idea what caused this, nor what's different now since i didnt change anything in the VI.
Might have been a problem with our internal network as well
(3,830 Views)
how??? i am also going through same issue.. my coding is given
(2,829 Views)
