Machine Vision
one image in two displays
Hello everyone:
FIrst of all thanks a lot for helping me.
I would like to do something really simple but it makes me crazy...
I would like that one image appears in two displays (with ROIs as well). My program take one photo and measure 5 ROIs so I wanto to visualize this photo with the rois en two displays because I have a tab control.
I just wire the two displays in the last "output photo" but just one display visualizes really good the photo whit the ROIs because the other displays visualizes good the photo bur not the ROIs.. The ROIs are intermittent in the second displays...
How can I solved that??
Thanks a lot!!!
(3,959 Views)
Can Anybody help me?!
(3,934 Views)
can you insert a screenshot !??
(3,929 Views)
If i understood you correctly, you just have to use to property nodes.
Greetings
Michael
(3,922 Views)
Hi michael.
I have done that as well and it works in the same way.... It makes me crazy... I don´t know what I am doing wrong.
Thanks for answering.
(3,912 Views)
you can do two think to do 1 duplicate image in one display and then use formula for roi any roi start than bigger that image size use- image size in this case you can use multi roi in one display 2 use copy image and then display it in others windows
(3,907 Views)
In my test this solution works. Its hard to think of problems in your code without seeing the VI. Could you post the VI or a simplified version of it that reproduces the Problem?
(3,891 Views)
