Machine Vision
imaq image control (Delete default Value)
I have a problem with the vision imaq image control.
I have defined for a "imaq image control" a default image for the development.
Now the default image is no longer need and i want to remove the default value an reset the Control to an empty image.
How can i reset the default Value from the "imaq image control" to an empty image?
Message 1 of 9
(5,937 Views)
Write empty image to this control and set it to default value, then save VI:
Message 2 of 9
(5,926 Views)
Accepted by topic author Cardinal1664
I have about 20 Vi's with imaq image controls with default images!
It must be possible to empty the image with a mouse click.
Like Array -> empty array
I don't want to too that progmaticaly!?
Message 3 of 9
(5,916 Views)
Hey,
unfortunately Andrey is right. Thats the only way.
Bets Regards
Gregor
Message 4 of 9
(5,911 Views)
OK thanks for the answer
Message 5 of 9
(5,907 Views)
Another possible way is to automate this task, something like this:
Just obtain list of VIs where Vision Control should be resetted to default, then run snippet above in the cycle.
Andrey.
Message 6 of 9
(5,899 Views)
Thanks Andrey for the code!
But isn't that a missing feature that you can click on the image Control an select ->empty image!?
Message 7 of 9
(5,890 Views)
Yes, it is. Proceed to LabVIEW Idea Exchange and submit your suggestion.
Message 8 of 9
(5,887 Views)
Ok. I suggested it:
Idea exchange
Message 9 of 9
(5,873 Views)
