09-04-2013 04:55 PM
i was using an max, to try to upgrade an evs1464rt, when it stop the communication between max and evs, ive been trying to make it work, but it just dont, doesnt detect the evs IP,
the monitor has no signal, but it seems to work ok, but just doesnt detect it..
i tryed using a usb to create Desktop PC Utility USB Drive
do i Have to format it?
if yes, How?
09-05-2013 10:28 AM
Hey there....
Before reseting the software on the EVS, try connecting the computer directly to the EVS and press the IP Reset and No App dip switches and reset the device. Set the computer IP to automatic, the EVS should reset to 192.169.254.x or even to 0.0.0.0. After that you can change the IP adress in MAX .
If that doesn't work, try connecting both the EVS and computer to a hub so that it can assign the IP adresses accordingly and place both devices on the same subnet
If you are using Vision Builder you can reinstall the EVS software from there.
Select the target and press Install/Reinstall Software
Hope this info helps...
Greetings
09-05-2013 04:23 PM
Try upgrading to MAX 5.5 by installing NI System Configuration 5.5.
http://joule.ni.com/nidu/cds/view/p/id/4086/lang/en
That should allow you to detect the target from MAX where you can format the target and change its network settings.
09-13-2013 05:20 PM
thanks, i already done it with this manual... chapter 4
09-13-2013 05:21 PM
i tried every ones solution, but didnt work,. thanks..
